跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad X41 Battery Replacement
  1. IBM ThinkPad X41 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn laptop over, make sure lid side is faced down.
  2. IBM ThinkPad X41 Battery Replacement: 步骤 2 中的图像 1,1
    • Locate battery release button lock on laptop, and press down.
  3. IBM ThinkPad X41 Battery Replacement: 步骤 3 中的图像 1,1
    • Hold laptop battery release button and gently pull battery away from laptop.
结论
团队
CSU Fullerton, Team 2-4, Bruce Fall 2016 CSU Fullerton, Team 2-4, Bruce Fall 2016 的会员
CSUF-BRUCE-F16S2G4
4 名成员
创作了8篇指南
2指南评论
How can you open the battery case and replace the lithium ion cells?
Janie Godfrey - 回复
This could be possible, but it's the hard way.
Open the battery case will be difficult, and you well need to keep the BMS circuit board inside the battery pack then build a battery pack with new cells and reactivate the BMS again as some battery BMS have a security that cut the power output when the BMS has stopped to be powered. So after replacing the cells, the battery might not work as is as the BMS might cut the power output of the battery pack.
I don't know if this battery pack has this kind of security on it's BMS.
Brendan -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 34
总计 1,312
