跳转到主内容
IBM ThinkPad T43 CD Drive Replacement
你所需要的
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: 步骤 1 中的图像 1,1
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: 步骤 2 中的图像 1,1
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: 步骤 3 中的图像 1,1
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: 步骤 4 中的图像 1,3 IBM ThinkPad T43 CD Drive Replacement: 步骤 4 中的图像 2,3 IBM ThinkPad T43 CD Drive Replacement: 步骤 4 中的图像 3,3
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: 步骤 5 中的图像 1,3 IBM ThinkPad T43 CD Drive Replacement: 步骤 5 中的图像 2,3 IBM ThinkPad T43 CD Drive Replacement: 步骤 5 中的图像 3,3
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: 步骤 6 中的图像 1,2 IBM ThinkPad T43 CD Drive Replacement: 步骤 6 中的图像 2,2
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: 步骤 7 中的图像 1,1
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
结论
另外一个人完成了本指南。
aLiX pIeRRe
于03/19/18注册
855 声望
创作了5篇指南
团队
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 UMass Dartmouth, Team S6-G4, Bernier Spring 2018 的会员
UMASSD-BERNIER-S18S6G4
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 889
