简介
Instructions to take out built in speakers inside the laptop.
配件
无需配件。
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
      • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
      • The bezel and keyboard will be loose, be careful.
  4. 所有超过US$100.00或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
    善于维修,即天赋异禀。
    与 #ImAGenius 分享您的维修故事
    我们都是天才
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
      • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. The metal bracket will now be free to move, grasp it and remove it from the device. The metal bracket will now be free to move, grasp it and remove it from the device.
    • The metal bracket will now be free to move, grasp it and remove it from the device.
  7. Remove the small rubber piece that is covering the T42's microphone,
    • Remove the small rubber piece that is covering the T42's microphone,
  8. This component is free to move.
    • This component is free to move.
  9. Disconnect its connector and pull it out carefully.
    • Disconnect its connector and pull it out carefully.
结论
Gerald Watanabe
于2010年04月14日注册
198 信誉积分
创作了7篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了30篇指南
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 7
总计 4,945
