简介
This guide will demonstrate the removal and replacement procedures for an IBM ThinkPad T42 Modem Daughter Board.
配件
无需配件。
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
  3. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  6. Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed. Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
    • Starting from the bottom right, carefully remove off the bezel. Use a spudger or flat head screwdriver if needed.
  7. The metal bracket will now be free to move, grasp it and remove it from the device. The metal bracket will now be free to move, grasp it and remove it from the device.
    • The metal bracket will now be free to move, grasp it and remove it from the device.
  8. Remove the small rubber piece that is covering the T42's microphone,
    • Remove the small rubber piece that is covering the T42's microphone,
  9. Next, unscrew the 3 Phillips screws in red.
    • Next, unscrew the 3 Phillips screws in red.
  10. The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
    • The cables are routed through different components for organization, carefully disconnect them, unwrap them and pull the card free.
  11. Lastly, remove the bracket sitting beneath it.
    • Lastly, remove the bracket sitting beneath it.
    • The end!
结论
另外一个人完成了本指南。
Gerald Watanabe
于2010年04月14日注册
198 信誉积分
创作了7篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了30篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 3
过去的30天: 17
总计 4,550
