跳转到主内容
IBM ThinkPad T42 Keyboard and Trackpad Replacement
你所需要的
  1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: 步骤 2 中的图像 1,1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard and Trackpad: 步骤 3 中的图像 1,1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Keyboard and Trackpad Replacement: 步骤 4 中的图像 1,2 IBM ThinkPad T42 Keyboard and Trackpad Replacement: 步骤 4 中的图像 2,2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
结论
3等其他人完成本指南。
Austin Kidd
于04/21/10注册
317 声望
创作了3篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了37篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 17
总计 10,324
