跳转到主内容
IBM ThinkPad T42 Hard Drive Replacement
你所需要的
  1. IBM ThinkPad T42 Hard Drive Replacement, Battery Clips: 步骤 1 中的图像 1,1
    • Flip the laptop over so the underside is facing you, then, release the 2 clips holding the battery on.
    • Make sure the laptop is off when you do this, sudden power outages can cause data corruption.
  2. IBM ThinkPad T42 Hard Drive Replacement, Removing the Battery: 步骤 2 中的图像 1,1
    • Carefully grab the battery, then pull it straight out, not at an angle.
  3. IBM ThinkPad T42 Hard Drive Replacement, Hard Drive Screw: 步骤 3 中的图像 1,1
    • Unscrew the single screw holding the drive cage in place.
  4. IBM ThinkPad T42 Hard Drive Replacement, Sliding Drive Out: 步骤 4 中的图像 1,1
    • Pull the hard drive out with of its bay the help of pictured ridges. Carefully remove it.
    • It might help to open the display slightly.
  5. IBM ThinkPad T42 Hard Drive Replacement, Removal of HDD: 步骤 5 中的图像 1,1
    • Pull the Hard Drive out and proceed with replacement.
结论
7等其他人完成本指南。
Austin Kidd
于04/21/10注册
317 声望
创作了3篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了35篇指南
一条评论
Excelente guía. Gracias
Luis Aguilar - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 20
过去 30 天: 89
总计 20,640
