跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad T42 Fan Replacement
你所需要的
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: 步骤 1 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: 步骤 2 中的图像 1,1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: 步骤 3 中的图像 1,1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: 步骤 4 中的图像 1,2 IBM ThinkPad T42 Fan Replacement: 步骤 4 中的图像 2,2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: 步骤 5 中的图像 1,2 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: 步骤 5 中的图像 2,2
    • Starting from the bottom right, carefully remove the bezel by pulling it up gently. If needed use a spudger or flathead screwdriver to help.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: 步骤 6 中的图像 1,2 IBM ThinkPad T42 Fan Replacement, Lower Bracket: 步骤 6 中的图像 2,2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: 步骤 7 中的图像 1,1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: 步骤 8 中的图像 1,2 IBM ThinkPad T42 Fan Replacement, Fan Removal: 步骤 8 中的图像 2,2
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
结论
8等其他人完成本指南。
Kevin Rehm
于04/19/10注册
472 声望
创作了4篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了37篇指南
2指南评论
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - 回复 分享
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 17
过去 30 天: 79
总计 27,054
