跳转到主内容
IBM ThinkPad T42 Display Replacement
你所需要的
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: 步骤 1 中的图像 1,1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Display Replacement, Rear screws: 步骤 2 中的图像 1,1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - 回复
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - 回复
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: 步骤 3 中的图像 1,1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement: 步骤 4 中的图像 1,2 IBM ThinkPad T42 Display Replacement: 步骤 4 中的图像 2,2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: 步骤 5 中的图像 1,2 IBM ThinkPad T42 Display Replacement, Bezel Removal: 步骤 5 中的图像 2,2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: 步骤 6 中的图像 1,1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
    could you post a pic of all the screws and where they go?
    Seth King - 回复
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: 步骤 7 中的图像 1,1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
结论
6等其他人完成本指南。
Austin Kidd
于04/21/10注册
317 声望
创作了3篇指南
团队
Cal Poly, Team 29-76, Johann Spring 2010 Cal Poly, Team 29-76, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G76
4 名成员
创作了35篇指南
2条评论
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - 回复
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 16
总计 13,025
