跳转到主内容
IBM ThinkPad T41 Speaker replacement
你所需要的
  1. IBM ThinkPad T41 Speaker replacement, Keyboard: 步骤 1 中的图像 1,1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
  2. IBM ThinkPad T41 Speaker replacement: 步骤 2 中的图像 1,1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
  3. IBM ThinkPad T41 Speaker replacement: 步骤 3 中的图像 1,1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 Speaker replacement: 步骤 4 中的图像 1,1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 Speaker replacement, Trackpad: 步骤 5 中的图像 1,1
    • Close the laptop and turn it over.
    • Remove the five plastic stickers covering the screws on the front edge of the case.
    • In order to reuse the stickers, remove them carefully.
  6. IBM ThinkPad T41 Speaker replacement: 步骤 6 中的图像 1,1
    • Unscrew the five screws that were hidden by the stickers.
  7. IBM ThinkPad T41 Speaker replacement: 步骤 7 中的图像 1,1
    • Turn the computer right side up and open the screen.
    • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
    • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
  8. IBM ThinkPad T41 Speaker replacement: 步骤 8 中的图像 1,1
    • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
  9. IBM ThinkPad T41 Speaker replacement, Speakers: 步骤 9 中的图像 1,1
    • Lift the speakers out by starting with the left end and then unsnake the wires.
  10. IBM ThinkPad T41 Speaker replacement: 步骤 10 中的图像 1,1
    • Unplug the wires from the motherboard.
结论
2等其他人完成本指南。
团队
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G8
4 名成员
创作了26篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 12,435
