跳转到主内容
加入维修社区 - 创建账户
IBM ThinkPad T41 Screen Replacement
你所需要的
    1. IBM ThinkPad T41 Screen Replacement, Keyboard: 步骤 1 中的图像 1,1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      添加评论
    2. IBM ThinkPad T41 Screen Replacement: 步骤 2 中的图像 1,1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      添加评论
    3. IBM ThinkPad T41 Screen Replacement: 步骤 3 中的图像 1,1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      询问修复机器人
      添加评论
    4. IBM ThinkPad T41 Screen Replacement: 步骤 4 中的图像 1,1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      询问修复机器人
      添加评论
    1. IBM ThinkPad T41 Screen Replacement, Trackpad: 步骤 5 中的图像 1,1
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      询问修复机器人
      添加评论
    2. IBM ThinkPad T41 Screen Replacement: 步骤 6 中的图像 1,1
      • Unscrew the five screws that were hidden by the stickers.
      询问修复机器人
      添加评论
    3. IBM ThinkPad T41 Screen Replacement: 步骤 7 中的图像 1,1
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      询问修复机器人
      添加评论
    4. IBM ThinkPad T41 Screen Replacement: 步骤 8 中的图像 1,1
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      询问修复机器人
      添加评论
    1. IBM ThinkPad T41 Screen Replacement, Wireless Network Card: 步骤 9 中的图像 1,1
      • Pull off the one black and one white coaxial cables by lifting the tabs labeled main and aux (for auxiliary).
      询问修复机器人
      添加评论
    2. IBM ThinkPad T41 Screen Replacement: 步骤 10 中的图像 1,1
      • Push apart the retaining clips.
      • Note: The card should pop up a little bit.
      询问修复机器人
      添加评论
    3. IBM ThinkPad T41 Screen Replacement: 步骤 11 中的图像 1,1
      • Pull the wireless network card out.
      询问修复机器人
      添加评论
    1. IBM ThinkPad T41 Screen Replacement, Screen: 步骤 12 中的图像 1,1
      • Close the computer screen.
      • Remove the four screws on the back of the laptop, near the right and left hinges.
      询问修复机器人
      添加评论
    2. IBM ThinkPad T41 Screen Replacement: 步骤 13 中的图像 1,1
      • Open the laptop screen.
      • Remove the single screw that secures the left hinge to top of the computer.
      询问修复机器人
      添加评论
    3. IBM ThinkPad T41 Screen Replacement: 步骤 14 中的图像 1,1
      • Remove a single screw from the metal plate that secures the display cable.
      询问修复机器人
      添加评论
    4. IBM ThinkPad T41 Screen Replacement: 步骤 15 中的图像 1,1
      • Pull the metal plate away from the display cable.
      询问修复机器人
      添加评论
    5. IBM ThinkPad T41 Screen Replacement: 步骤 16 中的图像 1,1
      • Disconnect the display cable.
      询问修复机器人
      添加评论
    6. IBM ThinkPad T41 Screen Replacement: 步骤 17 中的图像 1,1
      • Carefully pull up the long antenna cables that were attached to the wireless network card.
      询问修复机器人
      添加评论
    7. IBM ThinkPad T41 Screen Replacement: 步骤 18 中的图像 1,1
      • Lift out the screen.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
5等其他人完成本指南。
团队
Cal Poly, Team 7-8, Maness Spring 2010 Cal Poly, Team 7-8, Maness Spring 2010 的会员
CPSU-MANESS-S10S7G8
4 名成员
创作了91篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 45
总计 19,205
