跳转到主内容
本指南有最近更改,您可查看未经巡查的最新版本
IBM ThinkPad T30 Fan Assembly Replacement
你所需要的
  1. IBM ThinkPad T30 Fan Assembly Replacement, Battery: 步骤 1 中的图像 1,3 IBM ThinkPad T30 Fan Assembly Replacement, Battery: 步骤 1 中的图像 2,3 IBM ThinkPad T30 Fan Assembly Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure the ThinkPad is off and the power supply is unplugged.
    • Flip the ThinkPad upside down with the bottom facing you.
    • Slide the latch to the right into the unlock position.
    • While holding the latch in the unlock position, lift the battery out with your other hand.
  2. IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: 步骤 2 中的图像 1,2 IBM ThinkPad T30 Fan Assembly Replacement, Keyboard: 步骤 2 中的图像 2,2
    • Begin by removing the two black 16 mm Phillips #0 screws. The screws can be identified by the two notches next to each screw. One (marked in red) is near the battery lock and the other (not pictured) is next to the Wi-Fi cover.
    • Push up the bottom of the keyboard by poking your finger through the hole to the right of the yellow bios battery. You will feel slight resistance.
    • Be sure to not lift the keyboard too far. It is still attached to the computer with a ribbon connector.
  3. IBM ThinkPad T30 Fan Assembly Replacement: 步骤 3 中的图像 1,3 IBM ThinkPad T30 Fan Assembly Replacement: 步骤 3 中的图像 2,3 IBM ThinkPad T30 Fan Assembly Replacement: 步骤 3 中的图像 3,3
    • Lift the keyboard to expose the ribbon connector and lean it against the computer screen to keep the ribbon intact.
    • If the ribbon is broken, the keyboard is permanently unusable and needs to be replaced
    • Use the plastic opening tool to gently pry the connector up from the motherboard.
    • You can now safely remove the keyboard.
  4. IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: 步骤 4 中的图像 1,2 IBM ThinkPad T30 Fan Assembly Replacement, Fan Assembly: 步骤 4 中的图像 2,2
    • Remove the three 4 mm Phillips #0 screws securing the fan assembly.
  5. IBM ThinkPad T30 Fan Assembly Replacement: 步骤 5 中的图像 1,2 IBM ThinkPad T30 Fan Assembly Replacement: 步骤 5 中的图像 2,2
    • Using the plastic opening tool, gently pry the heat sink assembly up.
    • Be sure to reapply thermal compound on the processor and heat sink when reassembling the device.
    • Be aware that there still is a wire attached to the fan that is connected to motherboard upon removal.
  6. IBM ThinkPad T30 Fan Assembly Replacement: 步骤 6 中的图像 1,2 IBM ThinkPad T30 Fan Assembly Replacement: 步骤 6 中的图像 2,2
    • Using the plastic opening tool, gently lift the white connector out of its socket on the motherboard.
    • Before installing the new fan, remove all remnants of thermal compound from the top of the CPU. Warning—the stuff is hard to clean off clothing. Spread a small amount of fresh heat sink compound (DC-340 or equivalent) on the top of the CPU to form a thin coat. Be sure the mating fan heat sink is clean.
    • Follow iFixit's guide for [无效指南链接] for a detailed explanation.
结论
6等其他人完成本指南。
Alex Kost
于10/05/12注册
271 声望
创作了5篇指南
团队
Cal Poly, Team 3-20, Amido Fall 2012 Cal Poly, Team 3-20, Amido Fall 2012 的会员
CPSU-AMIDO-F12S3G20
3 名成员
创作了16篇指南
3条评论
There are two screws for keyboard removal! Almost snapped the keyboard in half trying to pry it off
Dima - 回复
Excellent instructions and very easy to follow (thanks for the pictures, they helped a lot!) Took me more than half an hour, but then I was trying to shove the teeny tiny white fan connector thing into the slot backwards..(my bad).. there is not a lot of room to maneuver in there. My ancient computer is working again and that makes me very happy, so thanks!
ML Hinrich - 回复
Really excellent instructions. Thank You for Your help!! Rolf Frey, Lucerne, Switzerland
Rolf Frey - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 4,696
