跳转到主内容
IBM ThinkPad A31 Keyboard Replacement
你所需要的
  1. IBM ThinkPad A31 Keyboard Replacement, Battery: 步骤 1 中的图像 1,2 IBM ThinkPad A31 Keyboard Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the ThinkPad over so that it is upside down.
    • Push latch switch to the left.
    • Gently lift the battery out and away from the ThinkPad
    • You have to hold the latch to the left while you remove the battery. Simply pushing once will not unlock the battery
  2. IBM ThinkPad A31 Keyboard Replacement, Keyboard: 步骤 2 中的图像 1,3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: 步骤 2 中的图像 2,3 IBM ThinkPad A31 Keyboard Replacement, Keyboard: 步骤 2 中的图像 3,3
    • The sticker is to keep the warranty on the laptop so once removed the warranty is void
    • Peel the sticker and remove the 15mm screw
    • Remove all 6 of the 16mm screws
  3. IBM ThinkPad A31 Keyboard Replacement: 步骤 3 中的图像 1,2 IBM ThinkPad A31 Keyboard Replacement: 步骤 3 中的图像 2,2
    • use a prying tool and insert it on the cracks on the sides of the keyboard and lift gently until you here a click
    • repeat this step on all sides of the keyboard until the keyboard is completely detached from the laptop
  4. IBM ThinkPad A31 Keyboard Replacement: 步骤 4 中的图像 1,3 IBM ThinkPad A31 Keyboard Replacement: 步骤 4 中的图像 2,3 IBM ThinkPad A31 Keyboard Replacement: 步骤 4 中的图像 3,3
    • Lift the keyboard and remove the keyboard ribbon cable from the laptop
结论
2等其他人完成本指南。
Matheus
于03/19/18注册
128 声望
撰写一个指南
团队
UMass Dartmouth, Team S2-G2, Bernier Spring 2018 UMass Dartmouth, Team S2-G2, Bernier Spring 2018 的会员
UMASSD-BERNIER-S18S2G2
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 22
总计 674
