跳转到主内容
IBM ThinkPad 600E Battery Replacement
  1. IBM ThinkPad 600E Battery Replacement, Battery: 步骤 1 中的图像 1,3 IBM ThinkPad 600E Battery Replacement, Battery: 步骤 1 中的图像 2,3 IBM ThinkPad 600E Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over and find the battery latch.
  2. IBM ThinkPad 600E Battery Replacement: 步骤 2 中的图像 1,1
    • Move the latch to the side with the unlocked symbol.
  3. IBM ThinkPad 600E Battery Replacement: 步骤 3 中的图像 1,3 IBM ThinkPad 600E Battery Replacement: 步骤 3 中的图像 2,3 IBM ThinkPad 600E Battery Replacement: 步骤 3 中的图像 3,3
    • Pry the battery out using your fingers.
结论
4等其他人完成本指南。
Kevin Nguyen
于10/04/16注册
737 声望
创作了4篇指南
团队
USF Tampa, Team 1-4, Nance Fall 2016 USF Tampa, Team 1-4, Nance Fall 2016 的会员
USFT-NANCE-F16S1G4
4 名成员
创作了12篇指南
2条评论
The IBM ThinkPad 600 battery uses six Panasonic Li-Ion cells in a 3Sx2P setup, and has a battery controller onboard the pack (under the lump covered by the IBM label). The problem has been that controller which limits the maximum energy output, especially if the pack is too hot. It has a fuse and a thermistor in between the cells. if the controller sees low voltages , the pack will be “open” yet the cells can still be good.
I have opened a pack manufactured in 1996 and the cells were good, such that I have recharged each cell pair directly. If you still have a ThinkPad 600 and several bad packs, open them carefully with a sharp blade along the plastic clamshell, remove the bottom, turn the pack with the label facing down, get a regulated Li-Ion cell charger, attach it carefully to the ends of each pair straps (the cells are welded together), and charge each pair until they have a minimum of 3.2 VDC each (or let it charge up to 4 VDC). Then tape the clamshell together and plug the pack in.
rayramirez - 回复
I am trying to find a video of how to change CMOS battery on my IBM ThinkPad 600E
Martyn Hunter - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 40
总计 2,058
