跳转到主内容
IBM ThinkPad 365XD CD Drive Replacement
你所需要的
  1. IBM ThinkPad 365XD CD Drive Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 1,3 IBM ThinkPad 365XD CD Drive Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 2,3 IBM ThinkPad 365XD CD Drive Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 3,3
    • Using both latches on the left and right side of the Thinkpad, lift up the screen.
    • Again using both latches, push them back while pushing the keyboard up till it pops up, then lift the keyboard up. You may need to use a little force.
  2. IBM ThinkPad 365XD CD Drive Replacement, Removing the Battery: 步骤 2 中的图像 1,2 IBM ThinkPad 365XD CD Drive Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Lift the battery using it's cloth pull tab and lift it out of the ThinkPad. Set it aside.
  3. IBM ThinkPad 365XD CD Drive Replacement, Removing Screws/Lifting Cover: 步骤 3 中的图像 1,2 IBM ThinkPad 365XD CD Drive Replacement, Removing Screws/Lifting Cover: 步骤 3 中的图像 2,2
    • Remove the following screws, there should be 3. Two of the screw spots may be slightly different on yours.
    • The cover has adhesive on it at these spots, pull it slowly till the adhesive releases. Then lift the cover up, you may need to hold it.
    • Keep track of the screws, the one that holds the drive to the board and cover is small, so don't loose it!
  4. IBM ThinkPad 365XD CD Drive Replacement, Removing CD Drive Screws/Cable: 步骤 4 中的图像 1,2 IBM ThinkPad 365XD CD Drive Replacement, Removing CD Drive Screws/Cable: 步骤 4 中的图像 2,2
    • Disconnect or remove the cable located above the drive, be careful as the cable is fragile.
    • You may use a flat head screwdriver or plier to remove the cable easier. Lightly push/lift up both sides of cable then pull it off.
    • Your drive should have 2 screws holding it down, remove them. They are small so keep track of them!
  5. IBM ThinkPad 365XD CD Drive Replacement, Removing  The CD-Drive: 步骤 5 中的图像 1,2 IBM ThinkPad 365XD CD Drive Replacement, Removing  The CD-Drive: 步骤 5 中的图像 2,2
    • Slide the drive down till it is out of the ThinkPad.
    • The ThinkPad uses a proprietary IDE connector, so not just any CD-Drive will work. Models that will work: Teac CD-44E, CD-46E, CD-48E.
结论
Olda1120
于07/04/18注册
399 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 674
