跳转到主内容
IBM ThinkPad 365 X/XD RAM Replacement
你所需要的
  1. IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 1,3 IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 2,3 IBM ThinkPad 365 X/XD RAM Replacement, Getting Inside the Thinkpad: 步骤 1 中的图像 3,3
    • Using both latches on the left and right side of the Thinkpad, lift up the screen.
    • Again using both latches, push them back while pushing the keyboard up till it pops up, then lift the keyboard up. You may need to use a little force.
  2. IBM ThinkPad 365 X/XD RAM Replacement, Removing the Battery: 步骤 2 中的图像 1,2 IBM ThinkPad 365 X/XD RAM Replacement, Removing the Battery: 步骤 2 中的图像 2,2
    • Lift the battery using it's cloth pull tab and lift it out of the ThinkPad. Set it aside.
  3. IBM ThinkPad 365 X/XD RAM Replacement, Removing Screws/Lifting Cover: 步骤 3 中的图像 1,2 IBM ThinkPad 365 X/XD RAM Replacement, Removing Screws/Lifting Cover: 步骤 3 中的图像 2,2
    • Remove the following screws, there should be 3. Two of the screw spots may be slightly different on yours.
    • The cover has adhesive on it at these spots, pull it slowly till the adhesive releases. Then lift the cover up, you may need to hold it.
    • Keep track of the screws, the one that holds the drive to the board and cover is small, so don't loose it!
  4. IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: 步骤 4 中的图像 1,3 IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: 步骤 4 中的图像 2,3 IBM ThinkPad 365 X/XD RAM Replacement, Removing the RAM stick: 步骤 4 中的图像 3,3
    • Using both hands, push the clips holding the RAM stick in outwards, till the RAM stick pops up.
    • Pull the stick out, and replace by pushing it in the same position you pulled it out, then down till the clips click.
    • Compatible with 144 pin 4x64-60ns EDO sticks. Some users have reported the ThinkPad can support up to 72 MB of ram using a 64 MB stick, but it has not worked for all users so there is no guarantee!
结论
Olda1120
于07/04/18注册
399 声望
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 18
总计 618
