跳转到主内容
Hytera TC-580 Speaker Replacement
你所需要的
  1. Hytera TC-580 Speaker Replacement, Battery: 步骤 1 中的图像 1,2 Hytera TC-580 Speaker Replacement, Battery: 步骤 1 中的图像 2,2
    • Remove the two 10mm Phillips #0 from the belt clip.
  2. Hytera TC-580 Speaker Replacement: 步骤 2 中的图像 1,2 Hytera TC-580 Speaker Replacement: 步骤 2 中的图像 2,2
    • Push in the release button and pull up on the battery to remove.
  3. Hytera TC-580 Speaker Replacement, Antenna: 步骤 3 中的图像 1,1
    • Twist antenna counter-clockwise and set damaged antenna aside.
  4. Hytera TC-580 Speaker Replacement, Keypad: 步骤 4 中的图像 1,1
    • Remove the volume knob by firmly lifting up on both sides of it.
  5. Hytera TC-580 Speaker Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the orange o-ring around volume knob using tweezers.
  6. Hytera TC-580 Speaker Replacement: 步骤 6 中的图像 1,1
    • Remove grey nut from base of volume knob by turning it counterclockwise with a set of tweezers.
  7. Hytera TC-580 Speaker Replacement: 步骤 7 中的图像 1,1
    • Remove the brass washer from the base of the antenna slot by turning it counterclockwise with a set of tweezers.
  8. Hytera TC-580 Speaker Replacement: 步骤 8 中的图像 1,2 Hytera TC-580 Speaker Replacement: 步骤 8 中的图像 2,2
    • Remove the two 15mm T8 Torx screws from the base of the battery cavity.
  9. Hytera TC-580 Speaker Replacement: 步骤 9 中的图像 1,1
    • Using a plastic opening tool, pry in between the plastic case and metal circuit board to remove the board.
  10. Hytera TC-580 Speaker Replacement: 步骤 10 中的图像 1,1
    • Peel off the keypad by hand.
  11. Hytera TC-580 Speaker Replacement, Speaker: 步骤 11 中的图像 1,3 Hytera TC-580 Speaker Replacement, Speaker: 步骤 11 中的图像 2,3 Hytera TC-580 Speaker Replacement, Speaker: 步骤 11 中的图像 3,3
    • Remove eleven 4mm Phillips #00 screws.
  12. Hytera TC-580 Speaker Replacement: 步骤 12 中的图像 1,1
    • Apply a soldering iron to the solder joints to remove the two wires connecting the speaker to the circuit board.
结论
Mohammed Chehab
于02/14/18注册
88 声望
撰写一个指南
团队
USF Tampa, Team S3-G4, Nance Spring 2018 USF Tampa, Team S3-G4, Nance Spring 2018 的会员
USFT-NANCE-S18S3G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 508
