跳转到主内容
HyperX QuadCast S Gain Control Knob Replacement
  1. HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: 步骤 1 中的图像 1,3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: 步骤 1 中的图像 2,3 HyperX QuadCast S Gain Control Knob Replacement, Gain Control Knob: 步骤 1 中的图像 3,3
    • Set the microphone on a flat surface.
    • Pull each of the support bands upwards and off of the notches to release the microphone from its base.
    • There are four support bands in total, but it does not matter which band you choose to take off first.
  2. HyperX QuadCast S Gain Control Knob Replacement: 步骤 2 中的图像 1,3 HyperX QuadCast S Gain Control Knob Replacement: 步骤 2 中的图像 2,3 HyperX QuadCast S Gain Control Knob Replacement: 步骤 2 中的图像 3,3
    • Orientate the microphone with the gain control knob upwards.
    • Pull outwards from the microphone to release the gain control knob.
    • It will not take much force to release the knob from the microphone. Be aware that a small "pop" may be heard once the knob is unplugged.
  3. HyperX QuadCast S Gain Control Knob Replacement: 步骤 3 中的图像 1,3 HyperX QuadCast S Gain Control Knob Replacement: 步骤 3 中的图像 2,3 HyperX QuadCast S Gain Control Knob Replacement: 步骤 3 中的图像 3,3
    • Remove the gain control knob.
    • The gain control knob connects to the tiny black pin indicated. When reattaching the knob, make sure to properly align the hole to the shape of the pin.
结论
另外一个人完成了本指南。
Nathan Arruda
于10/25/22注册
765 声望
创作了6篇指南
团队
UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 UMass Dartmouth, Team 4-1, Sinclaire Fall 2022 的会员
UMASSD-SINCLAIRE-F22S4G1
5 名成员
创作了9篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 40
总计 2,296
