跳转到主内容
HyperX CloudX Flight Battery Replacement
你所需要的
  1. HyperX CloudX Flight Battery Replacement, Battery: 步骤 1 中的图像 1,3 HyperX CloudX Flight Battery Replacement, Battery: 步骤 1 中的图像 2,3 HyperX CloudX Flight Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Gently pull around the perimeter of the right ear cup until the cushion is fully removed.
  2. HyperX CloudX Flight Battery Replacement: 步骤 2 中的图像 1,1
    • Unscrew the top of the speaker using a Phillips #00 screwdriver.
  3. HyperX CloudX Flight Battery Replacement: 步骤 3 中的图像 1,2 HyperX CloudX Flight Battery Replacement: 步骤 3 中的图像 2,2
    • Pull the battery out.
    • Desolder the battery wires from the circuit board.
    • Remember the order the wires are in; you will need to keep them in this order for the replacement.
结论
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 69
总计 563
