跳转到主内容
Hyggly Percussive Massage Gun Battery Replacement
你所需要的
  1. Hyggly Percussive Massage Gun Battery Replacement, Battery: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the 4 rubber stoppers on the massage gun.
    • You can use tweezers for ease or take the hard way and use your screwdriver.
  2. Hyggly Percussive Massage Gun Battery Replacement: 步骤 2 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the 1 Phillips head screw underneath the power button.
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws under the rubber stopper.
  3. Hyggly Percussive Massage Gun Battery Replacement: 步骤 3 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 3 中的图像 2,2
    • Twist and remove the circular black lid that houses the main circuit board.
    • Pull apart the main body of the massage gun. The gun should now be in three parts.
    • Detach the wires connected to the main circuit board.
    • Remember to write down which wire attaches where.
  4. Hyggly Percussive Massage Gun Battery Replacement: 步骤 4 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 4 中的图像 2,2
    • Using the Phillips #00 screwdriver, unscrew the 4 Phillips head screws inside the main body of the massage gun.
    • Pry open the lid once the screws are removed.
  5. Hyggly Percussive Massage Gun Battery Replacement: 步骤 5 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 5 中的图像 2,2
    • Remove the top cover from battery compartment.
    • Remove the rubber sleeve off the battery compartment.
  6. Hyggly Percussive Massage Gun Battery Replacement: 步骤 6 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 6 中的图像 2,2
    • Remove the sticker off the bottom of the battery compartment near the power switch.
    • Using the Phillips #00 screwdriver, unscrew the 3 Phillips head screws around the power switch to access the inside of the battery compartment.
  7. Hyggly Percussive Massage Gun Battery Replacement: 步骤 7 中的图像 1,1
    • Remove the bottom lid of the battery compartment to reveal the second circuit board.
    • Detach the wires of the battery from the circuit board.
    • Remember to write down the positioning of the wires.
  8. Hyggly Percussive Massage Gun Battery Replacement: 步骤 8 中的图像 1,1
    • Pry open the battery compartment
  9. Hyggly Percussive Massage Gun Battery Replacement: 步骤 9 中的图像 1,2 Hyggly Percussive Massage Gun Battery Replacement: 步骤 9 中的图像 2,2
    • Remove the old battery to replace the new one.
结论
另外一个人完成了本指南。
Raj Patel
于09/15/23注册
169 声望
撰写一个指南
团队
York University, Team D-22, O'Regan Fall 2023 York University, Team D-22, O'Regan Fall 2023 的会员
YORK-O'REGAN-F23SDG22
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 65
总计 335
