跳转到主内容
Husqvarna Viking Designer 1 Needle Replacement
你所需要的
  1. Husqvarna Viking Designer 1 Needle Replacement, Needle: 步骤 1 中的图像 1,2 Husqvarna Viking Designer 1 Needle Replacement, Needle: 步骤 1 中的图像 2,2
    • Remove the thread from the needle by pulling it out.
  2. Husqvarna Viking Designer 1 Needle Replacement: 步骤 2 中的图像 1,3 Husqvarna Viking Designer 1 Needle Replacement: 步骤 2 中的图像 2,3 Husqvarna Viking Designer 1 Needle Replacement: 步骤 2 中的图像 3,3
    • Turn the knob counterclockwise to life up the needle.
    • Turning the knob clockwise can damage the machine.
  3. Husqvarna Viking Designer 1 Needle Replacement: 步骤 3 中的图像 1,1
    • Place a sheet of paper under the foot. In the event that the needle falls out, this will prevent it from falling into the bobbin area.
  4. Husqvarna Viking Designer 1 Needle Replacement: 步骤 4 中的图像 1,2 Husqvarna Viking Designer 1 Needle Replacement: 步骤 4 中的图像 2,2
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to loosen the needle clamp screw (model: Viking #4125825-01) located next to the top of the needle with the other hand.
  5. Husqvarna Viking Designer 1 Needle Replacement: 步骤 5 中的图像 1,1
    • Discard the broken or unwanted needle, and select a new one.
  6. Husqvarna Viking Designer 1 Needle Replacement: 步骤 6 中的图像 1,2 Husqvarna Viking Designer 1 Needle Replacement: 步骤 6 中的图像 2,2
    • Insert the new needle with the flat side facing away from you.
  7. Husqvarna Viking Designer 1 Needle Replacement: 步骤 7 中的图像 1,1
    • Hold onto the needle with one hand, and use a Singer #412381501 screwdriver to tighten the needle clamp screw (model: Viking #4125825-01) with the other hand.
  8. Husqvarna Viking Designer 1 Needle Replacement: 步骤 8 中的图像 1,1
    • Thread the needle. (See pages 8-10 from the link.)
    • You may now remove the sheet of paper and begin sewing!
结论
Replacing the needle is a quick, easy task to complete, using the directions provided in this guide.
2等其他人完成本指南。
6条评论
Excellent illustration!!!
KO SAMUEL TAK SHUN - 回复
I have a Husqvarna viking designer se embroidery sewing machine and my needle threader broke had to purchased two needle threaders for my viking and one of them two big and the other one it's not the eye of the needle help I need a replacement asap thanks
Nenalinda0216 - 回复
Where do I purchase a vikking designer se needle threaders I search every where for that piece no luck 😢 thank you Nenalinda0216@yahoo.com Magali Rivera
Nenalinda0216 - 回复
I brought a replacement automatic needle threader and it fix on the viking & when I put it on the viking designer se it's doesnt line up in the eye of the needle and take the needle off and put it on again but it's still the same need help and I don't know what to do reply asap thanks
Nenalinda0216 - 回复
Hi my name is Magali and iam looking a replacement needle threaders for my husqvarna viking designer se embroidery sewing machine will someone answer me i search every where for a designer se needle threaders thank you!
Nenalinda0216 - 回复
Have a Husqvarna viking designer se and don't have the serial number for the sewing machine will you tell me how do I get the serial number is not on the viking designer se embroidery sewing machine cause my husband brought it on Facebook market need the serial number asap thanks Magali
Nenalinda0216 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 48
总计 1,563
