跳转到主内容
Huffy Kids Tricycle Seat Replacement
你所需要的
  1. Huffy Kids Tricycle Seat Replacement, Seat: 步骤 1 中的图像 1,2 Huffy Kids Tricycle Seat Replacement, Seat: 步骤 1 中的图像 2,2
    • Focus on the seat area for the replacement.
  2. Huffy Kids Tricycle Seat Replacement: 步骤 2 中的图像 1,2 Huffy Kids Tricycle Seat Replacement: 步骤 2 中的图像 2,2
    • Place the spanner on the bolt on the underside of the seat.
    • Then use a Phillips #2 screwdriver to remove the screw on the top of the seat.
  3. Huffy Kids Tricycle Seat Replacement: 步骤 3 中的图像 1,3 Huffy Kids Tricycle Seat Replacement: 步骤 3 中的图像 2,3 Huffy Kids Tricycle Seat Replacement: 步骤 3 中的图像 3,3
    • Repeat for the other screw.
  4. Huffy Kids Tricycle Seat Replacement: 步骤 4 中的图像 1,3 Huffy Kids Tricycle Seat Replacement: 步骤 4 中的图像 2,3 Huffy Kids Tricycle Seat Replacement: 步骤 4 中的图像 3,3
    • Lift the seat off of the trike frame.
  5. Huffy Kids Tricycle Seat Replacement: 步骤 5 中的图像 1,3 Huffy Kids Tricycle Seat Replacement: 步骤 5 中的图像 2,3 Huffy Kids Tricycle Seat Replacement: 步骤 5 中的图像 3,3
    • Place the new seat on the seat bracket, lining up the screw holes in the seat with the appropriate holes on the bracket.
    • Note that the bracket has two sets of holes for mounting the seat, so choose the appropriate set for the height of the rider. A taller rider will use the further set while a shorter rider will use the set closer to the handlebars.
    • Insert the screws from the top of the seat, using your spanner to hold the nuts under the screws.
  6. Huffy Kids Tricycle Seat Replacement: 步骤 6 中的图像 1,2 Huffy Kids Tricycle Seat Replacement: 步骤 6 中的图像 2,2
    • Give the seat a wiggle to check that it is tight against the bracket.
    • If there is any play, tighten the screws a few more turns.
结论
To reassemble your device, follow these instructions in reverse order and you should be able to accomplish this
团队
York University, Team F-4, Woodhouse Fall 2021 York University, Team F-4, Woodhouse Fall 2021 的会员
YORK-WOODHOUSE-F21SFG4
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 21
总计 581
