跳转到主内容
加入维修社区 - 创建账户
Huawei u7519 Camera Replacement
你所需要的
  1. Huawei u7519 Camera Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei u7519 Camera Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Take off the back covering of the phone along with the battery and SIM card.
    • The SIM card is located above the battery.
  2. Huawei u7519 Camera Replacement: 步骤 2 中的图像 1,2 Huawei u7519 Camera Replacement: 步骤 2 中的图像 2,2
    • Using the Phillips #00 Screwdriver, take out the four small screws located at the four corners of the phone.
  3. Huawei u7519 Camera Replacement: 步骤 3 中的图像 1,1
    • Using the same screwdriver, take out the two bigger screws located on each side of the battery compartment.
  4. Huawei u7519 Camera Replacement: 步骤 4 中的图像 1,1
    • Once all the screws are removed, use the iPod opening tool to pry off the back covering of the phone along the edge of the back cover and you will have access to the motherboard.
    • The power and volume buttons will fall out of the phone. Set aside for reassembly.
  5. Huawei u7519 Camera Replacement: 步骤 5 中的图像 1,1
    • Carefully pull the backing of the phone from the motherboard with your hands.
  6. Huawei u7519 Camera Replacement, Camera: 步骤 6 中的图像 1,2 Huawei u7519 Camera Replacement, Camera: 步骤 6 中的图像 2,2
    • To remove front encasing from the motherboard, first pull back the orange tabs.
  7. Huawei u7519 Camera Replacement: 步骤 7 中的图像 1,2 Huawei u7519 Camera Replacement: 步骤 7 中的图像 2,2
    • Once the orange tabs are pulled back, carefully pull the motherboard apart from the front casing.
  8. Huawei u7519 Camera Replacement: 步骤 8 中的图像 1,1
    • The camera is not removable from the motherboard. Therefore, a new motherboard must be purchased in order to replace the camera.
结论
2等其他人完成本指南。
团队
Ohio State, Team 1-1, Meza Spring 2014 Ohio State, Team 1-1, Meza Spring 2014 的会员
OSU-MEZA-S14S1G1
4 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 18
总计 697
