跳转到主内容
Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement
你所需要的
视频概述
  1. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 步骤 1 中的图像 1,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 步骤 1 中的图像 2,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Switch off the device: 步骤 1 中的图像 3,3
    • Turn off the device
    • Remove the sim tray
  2. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 步骤 2 中的图像 1,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 步骤 2 中的图像 2,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Back Cover: 步骤 2 中的图像 3,3
    • Use Plastic tool to separate the back cover
    • With a Phillips screwdriver remove two black screws and the battery flex connector shield
    • Disconnect the battery and the finger print sensor flex cable
  3. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 步骤 3 中的图像 1,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 步骤 3 中的图像 2,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal Part 1: 步骤 3 中的图像 3,3
    • Remove all screws from the top of the logic board
    • Remove the shield covering the camera connectors
    • Remove the screws and the plastic cover at the bottom of the device
    • Be careful! Different colored screws have different size
  4. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 步骤 4 中的图像 1,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 步骤 4 中的图像 2,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement, Logic Board Removal - Part 2: 步骤 4 中的图像 3,3
    • Disconnect the Screen Flex cable
    • Remove the logic board
    • Note that at the bottom side of board is attached to the display with double-sided tape
  5. Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 步骤 5 中的图像 1,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 步骤 5 中的图像 2,3 Huawei Y7 2018 (LDN-L21) Display Assembly with Frame Replacement: 步骤 5 中的图像 3,3
    • Now you have to transfer:
    • Receiver
    • Proximity sensor
    • Volume buttons flex
    • Vibration
    • Battery
结论
11等其他人完成本指南。
ZFix
于12/09/13注册
191,470 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
321 名成员
创作了1,482篇指南
一条评论
Can i get video guide
filmon - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 24
过去 30 天: 93
总计 6,652
