跳转到主内容
Huawei Y300 SIM Card Replacement
你所需要的
  1. Huawei Y300 SIM Card Replacement, Rear Cover: 步骤 1 中的图像 1,3 Huawei Y300 SIM Card Replacement, Rear Cover: 步骤 1 中的图像 2,3 Huawei Y300 SIM Card Replacement, Rear Cover: 步骤 1 中的图像 3,3
    • Remove the rear cover on the back by pulling up on the gap located at the bottom of the phone.
  2. Huawei Y300 SIM Card Replacement: 步骤 2 中的图像 1,1
    • Lift the battery with your finger up and out to remove the battery for replacement.
  3. Huawei Y300 SIM Card Replacement, Replace The Battery: 步骤 3 中的图像 1,1
    • After the battery is removed, replace the battery
    • Make sure the battery sits correctly by locating the power output at the bottom left.
  4. Huawei Y300 SIM Card Replacement, SIM Card: 步骤 4 中的图像 1,1
    • Remove the SIM card by sliding it upwards.
    • The gold plate on the SIM card should faced the back of the phone and the little dent sits at the bottom right.
    • Huawei Y300 will not accept micro SIM card.
结论
5等其他人完成本指南。
Anthony Ng
于10/19/14注册
1,433 声望
创作了2篇指南
团队
UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 5-3, Vijaybhaskar Fall 2014 的会员
UMASSD-VIJAYBHASKAR-F14S5G3
4 名成员
创作了8篇指南
一条评论
My Huawei Y300 doesn't read the Sim card when inserted. Why?
Evelyn - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 37
总计 4,779
