跳转到主内容
Huawei Watch Jewel Battery Replacement
你所需要的
  1. Huawei Watch Jewel Battery Replacement, Strap: 步骤 1 中的图像 1,2 Huawei Watch Jewel Battery Replacement, Strap: 步骤 1 中的图像 2,2
    • Begin by laying the watch on a flat, smooth surface.
    • This will prevent the watch screen from suffering damage.
    • Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
  2. Huawei Watch Jewel Battery Replacement: 步骤 2 中的图像 1,2 Huawei Watch Jewel Battery Replacement: 步骤 2 中的图像 2,2
    • Locate the two springs on the back of your watch.
    • The watch comes with two of these springs on each side of the back-face. These are used to release the straps from the body of the watch.
  3. Huawei Watch Jewel Battery Replacement: 步骤 3 中的图像 1,3 Huawei Watch Jewel Battery Replacement: 步骤 3 中的图像 2,3 Huawei Watch Jewel Battery Replacement: 步骤 3 中的图像 3,3
    • Use the Flex Extension to push the spring to the right. This will release the strap from the watch head.
  4. Huawei Watch Jewel Battery Replacement: 步骤 4 中的图像 1,1
    • Carefully pull the strap away from the watch.
  5. Huawei Watch Jewel Battery Replacement: 步骤 5 中的图像 1,2 Huawei Watch Jewel Battery Replacement: 步骤 5 中的图像 2,2
    • Repeat step 3, this time using the other strap.
  6. Huawei Watch Jewel Battery Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
  7. Huawei Watch Jewel Battery Replacement: 步骤 7 中的图像 1,2 Huawei Watch Jewel Battery Replacement: 步骤 7 中的图像 2,2
    • Use the Metal Spudger to pry open the back of your watch.
    • Make sure the watch is off and not plugged in when prying into the case with the Metal Spudger to avoid the risk of electric shock.
  8. Huawei Watch Jewel Battery Replacement: 步骤 8 中的图像 1,1
    • Remove the back case.
  9. Huawei Watch Jewel Battery Replacement: 步骤 9 中的图像 1,2 Huawei Watch Jewel Battery Replacement: 步骤 9 中的图像 2,2
    • Use tweezers or a nylon spudger to pry up the four press-fit connectors.
    • The glued-down connector in the middle is harder to remove than the rest. That is perfectly fine.
  10. Huawei Watch Jewel Battery Replacement: 步骤 10 中的图像 1,1
    • Locate the two Phillips #00 screws holding down the motherboard, and use the Phillips #00 screwdriver to remove them.
    • Ensure to place these screws separately from the Torx screws, as they can easily be mixed up.
  11. Huawei Watch Jewel Battery Replacement: 步骤 11 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Use the Metal Spudger to lift the mother board from the watch.
    • The metal spudger may cause damage to the device, use a black nylon spudger when possible.
  12. Huawei Watch Jewel Battery Replacement: 步骤 12 中的图像 1,1
    • Remove the motherboard.
  13. Huawei Watch Jewel Battery Replacement, Battery: 步骤 13 中的图像 1,1
    在这个步骤中使用的工具:
    iFixit Opening Picks (Set of 6)
    购买
    • Use the spudger or opening pick to carefully lift the battery from the watch.
    • Ensure that the polarity (+/- signs) of the new battery match that of the old battery when inserting new battery into device.
    • Avoid using a metal spudger as it may cause damage to the battery or device. Use an opening pick when possible.
结论
19等其他人完成本指南。
ngan tran
于02/15/17注册
498 声望
创作了2篇指南
团队
USF Tampa, Team 5-3, Passmore Spring 2017 USF Tampa, Team 5-3, Passmore Spring 2017 的会员
USFT-PASSMORE-S17S5G3
4 名成员
创作了3篇指南
8条评论
Any idea where one can purchase the actual battery? I can’t find one anywhere.
Chris Wellings - 回复
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
edgar.dumea - 回复
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
Alex Swanson -
thanks for this great guide, it’s very clear. My W1’s battery is still OK, but I’m anticipating needing to change it sometime and your guide removes the fear!
Paul M - 回复
T2 or T3 Torx ???
Carlos - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 36
过去 30 天: 108
总计 22,167
