简介
If you are experiencing shutter delay with your Huawei SnapTo G-620's camera, then the camera may need to be replaced. This guide shows you how to replace your SnapTo's camera.
你所需要的
Pry open the back cover with your fingernail, using the divot to the lower left hand corner.
Remove all fifteen 4mm Phillips J00 screws on the back panel.
Using a metal spudger or your fingernail, remove the back panel.
即将完成!
结论
