简介
If the display of your Huawei P9 Plus is cracked or broken use this guide to remove and replace it.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
你所需要的
Remove the sticker that sits on top of the left screw above the battery.
Remove the three Phillips #00 screws that hold the metal plates in place.
Use a tweezer to remove the sticker that sits on top of the screw next to the antenna cable.
Unplug the antenna cable and release it from the bracket on the metal plate covering the main flex cable.
Remove the four Phillips #00 screws.
Use an iOpener to loosen the adhesive under the display of your phone. It is mainly placed around the edge of the display.
After you have heated the sides, concentrate on the bottom part.
To reassemble your device, follow these instructions in reverse order and apply new adhesive where necessary.
5等其他人完成本指南。
