跳转到主内容
Huawei P9 Lite Headphone Jack Replacement
你所需要的
  1. Huawei P9 Lite Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei P9 Lite Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use an opening pick to unclip the rear cover, starting from the bottom corner.
    • Work your way around counterclockwise and carefully pry the plastic tabs open one by one.
  2. Huawei P9 Lite Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • There is adhesive underneath the back cover that holds it to the battery and the metal plate at the top.
    • Be careful with the flex cable at the right hand side.
    • Twist the opening pick to lever the back cover away and loosen it from the adhesive.
  3. Huawei P9 Lite Headphone Jack Replacement: 步骤 3 中的图像 1,1
    • When the back cover is freed from the adhesive you can pop it off by hand completely.
  4. Huawei P9 Lite Headphone Jack Replacement, Motherboard Shield: 步骤 4 中的图像 1,1
    • Remove the nine Phillips #00 screws that secure the metal shield plate.
    • Some screws may be covered with tamper proof stickers. Remove them to ensure a proper seating for your driver.
  5. Huawei P9 Lite Headphone Jack Replacement: 步骤 5 中的图像 1,2 Huawei P9 Lite Headphone Jack Replacement: 步骤 5 中的图像 2,2
    • Do not remove the shield plate yet, it is attached by a connector and an adhered cable.
    • Use a spudger to disconnect the fingerprint sensor from the motherboard.
    • Peel the NFC antenna cable off of the metal plate.
  6. Huawei P9 Lite Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 1,2 Huawei P9 Lite Headphone Jack Replacement, Headphone Jack: 步骤 6 中的图像 2,2
    • Disconnect the headphone jack with a spudger.
    • Take the headphone jack out of its recess.
结论
8等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
202,836 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,734篇指南
一条评论
After replacing my audio jack only one side work using headphones
jan call me - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 6,849
