跳转到主内容
Huawei P8 Lite Motherboard Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Huawei P8 Lite Motherboard Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei P8 Lite Motherboard Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Use an Opening Tool and start to lever up the back cover of your Huawei P8 Lite at the bottom of your phone.
  2. Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 1,3 Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 2,3 Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 3,3
    • There are clips around the whole mid frame, holding down the back cover. Open all of them with the Opening Tool.
    • When all clips are open, remove the back cover from the rest of the phone.
    • If the back cover doesn't come freely, there are probably some additional clips that need to be disconnected.
  3. Huawei P8 Lite Motherboard Replacement, Loudspeaker: 步骤 3 中的图像 1,1
    • Use a tweezer to remove the warranty sticker which sits on a screw in the bottom right of your phone.
  4. Huawei P8 Lite Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the 4 black Torx T5 screws which hold down the lower part of the loudspeaker.
    • Remove the three silver Phillips #00 screws which hold down the upper part of the loudspeaker.
  5. Huawei P8 Lite Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the loudspeaker carefully.
  6. Huawei P8 Lite Motherboard Replacement, Motherboard: 步骤 6 中的图像 1,1
    • Continue by removing the SIM and SD card trays on the side of the device.
  7. Huawei P8 Lite Motherboard Replacement: 步骤 7 中的图像 1,3 Huawei P8 Lite Motherboard Replacement: 步骤 7 中的图像 2,3 Huawei P8 Lite Motherboard Replacement: 步骤 7 中的图像 3,3
    • Remove the two Torx T5 screws. One may be cover with a liquid indicator.
    • Remove the five Phillips #000 screws.
    • Take away both securing brackets covering the motherboard.
    • If your phone has an NFC antenna, taking away the cover will automatically free its flex connector from the motherboard.
  8. Huawei P8 Lite Motherboard Replacement: 步骤 8 中的图像 1,1
    • Remove the three Phillips #000 screws on the silver panel.
  9. Huawei P8 Lite Motherboard Replacement: 步骤 9 中的图像 1,2 Huawei P8 Lite Motherboard Replacement: 步骤 9 中的图像 2,2
    • Carefully separate the four connectors holding the motherboard in place.
    • Remove the motherboard from the device.
结论
6等其他人完成本指南。
团队
USF Tampa, Team 1-1, Kass Spring 2017 USF Tampa, Team 1-1, Kass Spring 2017 的会员
USFT-KASS-S17S1G1
5 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,104
