跳转到主内容
Huawei P8 Lite Motherboard Replacement
你所需要的
  1. Huawei P8 Lite Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Remove the SIM card tray.
    • Use the SIM Card Eject Tool to click the pins located in two small holes on the side of the phone.
  2. Huawei P8 Lite Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the back cover.
    • The cover is not fastened with screws or adhesive, so you can use your finger nails, plastic spudger or other tools.
  3. Huawei P8 Lite Motherboard Replacement: 步骤 3 中的图像 1,1
    • Use the screwdrivers from 54 Bit Driver Kit to undo the screws. Be sure to keep the screws separated on your work surface to avoid confusion during the assembly.
    • PH000 Bit
    • T5 Torx
  4. Huawei P8 Lite Motherboard Replacement: 步骤 4 中的图像 1,1
    • Gently pull the connectors attached to the motherboard to disconnect them. See the highlighted areas in the photos.
    • These connectors are extremely fragile, so avoid using any kind of tools and make sure to be extremely gentle in the process.
  5. Huawei P8 Lite Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the motherboard carefully.
    • Replace the motherboard with the new one. To reassempble the phone, follow the teardown process guide in the reverse order.
结论
8等其他人完成本指南。
Brayden Mann
于02/05/16注册
639 声望
创作了4篇指南
团队
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 的会员
MSU-CARPENTER-S16S1G2
3 名成员
创作了7篇指南
4条评论
Anywhere to buy this motherboard? Maybe display as well?
Jan Šinkovec - 回复
mine also need a new mother
anywr l can get it asap
blessed - 回复
Hey
I need p8 lite motherboard
goitsemodimo - 回复
I had to resort to some tips on how to disassemble P8 LITE to change the micro usb charger. Thanks for sharing.
Alvaro Gomes - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 8,155
