跳转到主内容
Huawei P8 Lite Loudspeaker Replacement
你所需要的
  1. Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: 步骤 1 中的图像 1,2 Huawei P8 Lite Loudspeaker Replacement, Remove  Back Cover and Loudspeaker: 步骤 1 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Use the Spudger tool to get access to the loudspeaker. Locate where the headphone jack is, then move about one-inch to the right and begin to gently pry the back-cover off the phone with the flat end of the Spudger tool. Make sure to pry apart the entire perimeter of the back-cover to prevent bending/cracking of the plastic.
    • Tools used: Spudger tool (used as a wedge to pry off the back-cover and loudspeaker.)
  2. Huawei P8 Lite Loudspeaker Replacement: 步骤 2 中的图像 1,1
    • Remove three silver Phillips 000 screws.
    • Remove four T5 Torx screws.
  3. Huawei P8 Lite Loudspeaker Replacement: 步骤 3 中的图像 1,2 Huawei P8 Lite Loudspeaker Replacement: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    Spudger
    $2.99
    • Gently, use the flat end of the Spudger tool, or a metal opening tool to lift and remove the loudspeaker from the phone. The loudspeaker is the entire portion of the phone where the screws were extracted.
结论
To reassemble your device, follow Teardown Guide steps 4, 3, 2, 1 in that order.
2等其他人完成本指南。
Brayden Mann
于02/05/16注册
645 声望
创作了4篇指南
团队
Metro State, Team 1-2, Carpenter Spring 2016 Metro State, Team 1-2, Carpenter Spring 2016 的会员
MSU-CARPENTER-S16S1G2
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,418
