简介
请使用本指南更换华为P8 Lite(2017)中的破旧或没电的电池。
如果电池膨胀,采取适当的预防措施。为了您的安全,在拆卸手机之前,请“使电池电量低于25%”。如果在维修过程中意外损坏了电池,则可以减少发生危险的热事件的风险。
重新组装设备时,你需要更换粘合剂来重新连接组件。
你所需要的
如果可能的话,在安装新的粘合剂并重新密封之前,请先打开设备并测试维修情况。
要重新组装设备,请按照逆序进行操作。用异丙醇(> 90%)清洁相关区域后,如有必要,请应用新的粘合剂。
为了获得最佳性能,请“校准新安装的电池”:将其充电至100%,并继续充电至少2个小时以上。然后使用你的设备,直到由于电池电量不足而将其关闭。最后,不间断充电至100%。
将你的电子垃圾带到R2或e-Stewards认证回收商。
维修没有按计划进行吗?尝试一些基本故障排除,或询问我们的论坛寻求帮助。
5等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
4条评论
Hi there, thank you for this guide. I was just wondering what adhesive/ adhesive tape to use when re assembling the phone as I’m not familiar with what is suitable? Also, is there a particular brand of isopropyl alcohol to get? All the best, Ruari.
Hi Ruari, take a look at our store. You will find a range of different adhesives there. For the attachment of your battery I recommend these stretch battery adhesive. For the reassembly you can use this tape or another thin double-sided tape. For removing any remaining adhesive you can use this adhesive remover or remove large chunks of adhesives with your fingers, spudger, plastic opening tool, or tweezers. Good luck and have fun with your repair!
Hi ! Thanks for this really good tutorial. I changed my battery and everything seems to work until now, I hope it will continue for a long time! My only trouble is maybe that I have the double-sided adhesive tape from iFixit and only this material to "glue" the new battery. So, I hope this one will stick like the original one, we will see (:
Thanks a lot again, and have a good day. Tested on Huawei P8 Lite 2017, Model: PRA-LX1 Avril 2022
Hi @Rai, thanks for sharing your experience! We're glad to hear that your repair was successful. Normally the battery should be held in place with double sided tape.
