跳转到主内容
Huawei P20 Pro Rear Camera Lens Replacement
  1. Huawei P20 Pro Rear Camera Lens Replacement, Rear Camera Lens: 步骤 1 中的图像 1,1
    • Start by placing your phone screen down on a clean, well-lit surface.
    • Wear safety glasses/goggles to protect your eyes from glass shards. This is very important.
  2. Huawei P20 Pro Rear Camera Lens Replacement: 步骤 2 中的图像 1,2 Huawei P20 Pro Rear Camera Lens Replacement: 步骤 2 中的图像 2,2
    • Start removing the tiny shards of glass with straight precision tweezers. Place the shards of glass in a container for safe disposal.
    • A heat gun or a hair dryer may be helpful for loosening the adhesive on the glass.
  3. Huawei P20 Pro Rear Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Once the area is well cleaned, apply 2 dots of glue (B7000) on each end on the back of the new lens.
    • If not available, place double-sided adhesive strips in the gaps between the cameras.
    • Reposition the replacement lens in the broken lens’ original location, being careful not to leave any marks or debris on the inside of the camera area.
  4. Huawei P20 Pro Rear Camera Lens Replacement: 步骤 4 中的图像 1,1
    • All done! You can take pictures again like you were able to do before.
结论
After replacing the camera lens, clean it with a microfiber cloth to remove dust and/or fingerprints.
20等其他人完成本指南。
由衷感谢以下译者:
fr en
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
cPix
于06/14/16注册
4,136 声望
创作了8篇指南
2条评论
Tuto très bien expliquer je vais pouvoir maintenant reprendre de belles photos grâce à vous. Merci
Ace Ace - 回复
Für das Erwärmen beim Lösen oder Anbringen des neuen Kameraglases mit Klebestreifen empfiehlt sich eine Wärmflasche. Klebereste lassen sich effektiv mit Alkohol, zum Beispiel Isopropanol, entfernen. Um die Sicht zu verbessern, können günstige Lesebrillen (+3 dpt) aus dem Supermarkt für wenige Euros als Lupe genutzt werden.
256 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 67
总计 59,067
