简介
Use this guide to replace the front facing camera in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
你所需要的
Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
Remove the three Phillips #000 screws.
Use tweezers to remove the two metal shields which cover the flex cables on the mainboard.
Disconnect the flex cable of the front facing camera with a spudger.
Flip the motherboard and grab the front facing camera with tweezers. Thread the flex cable through the gap in the motherboard.
Remove the front facing camera.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
另外一个人完成了本指南。
