跳转到主内容
Huawei P10 Headphone Jack Replacement
你所需要的
  1. Huawei P10 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 1,3 Huawei P10 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 2,3 Huawei P10 Headphone Jack Replacement, Back Cover: 步骤 1 中的图像 3,3
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Headphone Jack Replacement: 步骤 2 中的图像 1,3 Huawei P10 Headphone Jack Replacement: 步骤 2 中的图像 2,3 Huawei P10 Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Headphone Jack Replacement: 步骤 3 中的图像 1,2 Huawei P10 Headphone Jack Replacement: 步骤 3 中的图像 2,2
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Headphone Jack Replacement, Battery disconnect: 步骤 4 中的图像 1,3 Huawei P10 Headphone Jack Replacement, Battery disconnect: 步骤 4 中的图像 2,3 Huawei P10 Headphone Jack Replacement, Battery disconnect: 步骤 4 中的图像 3,3
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 1,2 Huawei P10 Headphone Jack Replacement, Headphone Jack: 步骤 5 中的图像 2,2
    • Remove the three Phillips #00 screws.
  6. Huawei P10 Headphone Jack Replacement: 步骤 6 中的图像 1,2 Huawei P10 Headphone Jack Replacement: 步骤 6 中的图像 2,2
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
结论
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
2等其他人完成本指南。
Dominik Schnabelrauch
于11/23/16注册
203,299 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
135 名成员
创作了16,817篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 2,905
