跳转到主内容
Huawei MediaPad S7-301u Screen Replacement
你所需要的
  1. Huawei MediaPad S7-301u Screen Replacement, Battery: 步骤 1 中的图像 1,3 Huawei MediaPad S7-301u Screen Replacement, Battery: 步骤 1 中的图像 2,3 Huawei MediaPad S7-301u Screen Replacement, Battery: 步骤 1 中的图像 3,3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Screen Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Screen Replacement: 步骤 3 中的图像 1,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 3 中的图像 2,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 3 中的图像 3,3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Screen Replacement: 步骤 4 中的图像 1,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 4 中的图像 2,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 4 中的图像 3,3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Screen Replacement, Motherboard: 步骤 5 中的图像 1,3 Huawei MediaPad S7-301u Screen Replacement, Motherboard: 步骤 5 中的图像 2,3 Huawei MediaPad S7-301u Screen Replacement, Motherboard: 步骤 5 中的图像 3,3
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Screen Replacement: 步骤 6 中的图像 1,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 6 中的图像 2,3 Huawei MediaPad S7-301u Screen Replacement: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Screen Replacement: 步骤 7 中的图像 1,2 Huawei MediaPad S7-301u Screen Replacement: 步骤 7 中的图像 2,2
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Screen Replacement, Screen: 步骤 8 中的图像 1,1
    • Remove the 7 2mm screws for on the metal frame. Use a J000 screwdriver.
  9. Huawei MediaPad S7-301u Screen Replacement: 步骤 9 中的图像 1,2 Huawei MediaPad S7-301u Screen Replacement: 步骤 9 中的图像 2,2
    • Carefully remove the LCD from the front glass casing.
    • While separating the LCD from the device, be careful not to introduce any debris.
结论
3等其他人完成本指南。
Miguel Lugo
于09/26/17注册
598 声望
创作了3篇指南
团队
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 21
总计 2,522
