简介
A front-facing camera is a camera in the tablet that is usually situated on the front of the device just above the screen. It is a good piece of hardware to use as a webcam or taking selfie with it. You can use the front-facing camera in conversations over communication apps like Skype, Google Hangouts, WhatsApp, etc. If the front camera does not work properly, you will either have to do some troubleshooting to check and see if it is a hardware problem, or the front camera might simply need a replacement.
你所需要的
Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
Once the battery is removed, the motherboard is ready to be removed.
Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
Once the battery is removed, remove the front facing camera from the socket located on the top left of the tablet.
另外一个人完成了本指南。
