跳转到主内容
Huawei MediaPad S7-301u Battery Replacement
你所需要的
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: 步骤 1 中的图像 1,3 Huawei MediaPad S7-301u Battery Replacement, Battery: 步骤 1 中的图像 2,3 Huawei MediaPad S7-301u Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: 步骤 2 中的图像 1,1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: 步骤 3 中的图像 1,3 Huawei MediaPad S7-301u Battery Replacement: 步骤 3 中的图像 2,3 Huawei MediaPad S7-301u Battery Replacement: 步骤 3 中的图像 3,3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: 步骤 4 中的图像 1,3 Huawei MediaPad S7-301u Battery Replacement: 步骤 4 中的图像 2,3 Huawei MediaPad S7-301u Battery Replacement: 步骤 4 中的图像 3,3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
结论
5等其他人完成本指南。
Miguel Lugo
于09/26/17注册
598 声望
创作了3篇指南
团队
USF Tampa, Team S11-G5, Passmore Fall 2017 USF Tampa, Team S11-G5, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S11G5
4 名成员
创作了8篇指南
一条评论
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 25
总计 7,240
