简介
Use this guide to replace a worn out or defective battery.
你所需要的
Choose a side of the tablet to start; i took the one with the home button and heat it with the iOpener
Heat up the rest of the tablet
Put the suction handle roughly where the home button is and try to lift the display so you can slide with a pick between the display and the back cover. Be paitent it may take a while.
Take a second pick and try to get between display and the back cover
Once you are in with this pick move the pick from the middle to one of the edges
Insert another pick and move along the whole side of the tablet up to the next edge of the tablet
Same procedure as on the other sides. Take another pick and move it to the next corner of the tablet
With the tablet in standard landscape orientation lift the display to the right.
Remove one screw from the battery connector plate
Remove two screws from the display connector plate
Use a pair of tweezers to remove the display connector plate
Use a spudger to disconnect the display
Carefully dribble Isopropanol in the gap between the battery and edge of the battery well
Start with a pick to get under the battery. Move the pick along all sides of the battery. It can be difficult as the battery is glued over the entire surface of the well.
If the battery won´t move enough use some more Isopropanol
在这个步骤中使用的工具:Plastic Cards$2.99
Once you have soften the adhesive enough, you can use a bigger tool e.g. a plastic card.
Remove the battery
另外一个人完成了本指南。
