跳转到主内容
Huawei Mate 9 Rear and Front Camera Replacement
你所需要的
  1. Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 步骤 1 中的图像 1,3 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 步骤 1 中的图像 2,3 Huawei Mate 9 Rear and Front Camera Replacement, Rear and Front Camera: 步骤 1 中的图像 3,3
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Huawei Mate 9 Rear and Front Camera Replacement: 步骤 2 中的图像 1,3 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 2 中的图像 2,3 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 2 中的图像 3,3
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Huawei Mate 9 Rear and Front Camera Replacement: 步骤 3 中的图像 1,2 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 3 中的图像 2,2
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  4. Huawei Mate 9 Rear and Front Camera Replacement: 步骤 4 中的图像 1,2 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 4 中的图像 2,2
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  5. Huawei Mate 9 Rear and Front Camera Replacement: 步骤 5 中的图像 1,3 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 5 中的图像 2,3 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 5 中的图像 3,3
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  6. Huawei Mate 9 Rear and Front Camera Replacement: 步骤 6 中的图像 1,2 Huawei Mate 9 Rear and Front Camera Replacement: 步骤 6 中的图像 2,2
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
结论
2等其他人完成本指南。
Rogelio Ramirez
于06/25/17注册
524 声望
创作了3篇指南
团队
UC Davis, Team S7-G8, Lore Fall 2018 UC Davis, Team S7-G8, Lore Fall 2018 的会员
UCD-LORE-F18S7G8
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 2,110
