跳转到主内容
Huawei Mate 8 Loudspeaker Replacement
你所需要的
  1. Huawei Mate 8 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Switch off your phone and remove the SIM card tray.
  2. Huawei Mate 8 Loudspeaker Replacement: 步骤 2 中的图像 1,1
    • Remove the Torx T2 screws from the bottom of the phone
  3. Huawei Mate 8 Loudspeaker Replacement: 步骤 3 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement: 步骤 3 中的图像 2,2
    • Use an iSclack or a suction handle in the bottom area of your phone to separate the display unit from the rear panel.
  4. Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 4 中的图像 3,3
    • Use an opening pick to fully separate the clips, releasing the phone.
    • Do not fully remove the rear case. The fingerprint sensor cable is still connected to the back cover.
    • Open the phone like a book from the SIM tray side.
    • Use a spudger, to disconnect the fingerprint sensor cable.
  5. Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Daughterboard interconnect cable: 步骤 5 中的图像 3,3
    • Remove the liquid indicator sticker.
    • Remove the Phillips #00 screw that holds down the metal shield.
    • The metal shield is tightly held in place. If you try to remove it without holding it down on one side, it'll break easily.
    • Use a spudger to remove the metal shield.
  6. Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement: 步骤 6 中的图像 3,3
    • Use the flat end of a spudger to disconnect the display, daughterboard interconnect, and battery cables.
  7. Huawei Mate 8 Loudspeaker Replacement: 步骤 7 中的图像 1,1
    • Remove the Phillips #00 screw that holds down the interconnect cable bracket.
  8. Huawei Mate 8 Loudspeaker Replacement: 步骤 8 中的图像 1,2 Huawei Mate 8 Loudspeaker Replacement: 步骤 8 中的图像 2,2
    • Lift the coaxial connector off of its socket to allow access to the daughterboard interconnect cable bracket.
    • Remove the bracket.
  9. Huawei Mate 8 Loudspeaker Replacement: 步骤 9 中的图像 1,1
    • Use a spudger to disconnect the interconnect cable.
    • Remove the interconnect cable.
  10. Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Charging Board: 步骤 10 中的图像 3,3
    • Remove the two Phillips #00 screws.
    • Use the flat end a spudger to disconnect the loudspeaker flex connector.
    • Use the pointy end of a spudger to pry out the daughterboard.
    • Remove the daughterboard.
  11. Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 1,3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 2,3 Huawei Mate 8 Loudspeaker Replacement, Loudspeaker: 步骤 11 中的图像 3,3
    • Use the tip of a spudger on the left side of the loudspeaker to pry it out.
    • Remove the loudspeaker.
结论
4等其他人完成本指南。
Theo Mat
于11/12/17注册
12,938 声望
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 21
总计 1,076
