简介
使用本指南更换华为 Mate 10 Pro 的后盖。
如果电池膨胀,请勿加热手机。膨胀的电池可能非常危险,因此请戴好眼睛保护装置并谨慎操作,如果不确定如何继续使用,请交给专业人员。
你所需要的
关闭手机。
准备一个 iOpener 并将其应用到手机背面约两分钟,以软化后盖下方的粘合剂。
Erm… Simply impossible to open the phone this way…
I used the iOpener for 2 mins as instructed, I’ve used even an hair drier for 30 secs on max power (could barely touch the phone after) and still with the suction tool I was not able to open the phone.
It simply doesn’t budge!!!
This was much easier than I expected! ;-)
I put the phone on a hot-water bottle for about 5 minutes. I put the first pick in the side of the phone, not the top as shown in the next section. Then I kept the phone on the hot water bottle through all the following steps so that the battery glue was nice and warm when it came to that section.
用吸盘提起后盖,直到可以插入撬棒的扁平端。
使用撬棒在手机背面的后盖下方切割粘合剂。
Faire attention à ne pas enfoncer trop le cutter/spatule hallebarde. Surtout à l’approche des boutons ON/OFF et volume, la nappe ne passe pas loin et se branche à coté de l’empreinte digitale.
Bilan, j’ai coupé cette nappe et n’ai plus de bouton volume et on/off.
Plus qu’à chercher la piece de rechange pendant que le telephone est ouvert ;)
I found it easiest to insert the first pick on the side of the phone, not the top as shown in the pictures. The side is slightly more flexible than the ends because it is longer.
将后盖翻转到侧面。
拧下按住金属屏蔽罩的Phillips#00号螺丝,该螺钉位于指纹传感器电缆连接的顶部。
When re-assembling, you can test the phone before putting the covers back on. If you test it before you connect the fingerprint reader then you need to re-start the phone before the fingerprint reader will work.
请按逆序重组你的设备。
请按逆序重组你的设备。
11等其他人完成本指南。
由衷感谢以下译者:
100%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
2条评论
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Thanks for good work you do
