跳转到主内容
Huawei Ideos S7 Slim Touchscreen Replacement
你所需要的
  1. Huawei Ideos S7 Slim Touchscreen Replacement, Battery: 步骤 1 中的图像 1,3 Huawei Ideos S7 Slim Touchscreen Replacement, Battery: 步骤 1 中的图像 2,3 Huawei Ideos S7 Slim Touchscreen Replacement, Battery: 步骤 1 中的图像 3,3
    • Place the tablet on a flat clear surface to keep the screen safe.
    • Slide the larger portion of the back cover off the tablet.
    • This will reveal the battery.
  2. Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 2 中的图像 1,2 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 2 中的图像 2,2
    • Lift the battery out with your finger.
    • Make sure you use the slot near the bottom of the device as shown. Trying to lift from anywhere else will not work and may damage the battery or the device.
  3. Huawei Ideos S7 Slim Touchscreen Replacement, Logic Board: 步骤 3 中的图像 1,2 Huawei Ideos S7 Slim Touchscreen Replacement, Logic Board: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
  4. Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 4 中的图像 1,1
    • With a T5 hexagonal head, remove the nine black 2.5 mm torx screws. Place them carefully aside on the magnetic mat.
  5. Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 5 中的图像 1,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 5 中的图像 2,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 5 中的图像 3,3
    • Using a plastic opening tool, pry off the back casing gently on each side of the tablet.
  6. Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 6 中的图像 1,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 6 中的图像 2,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 6 中的图像 3,3
    • Using a Phillips #00 screwdriver, remove the following screws:
    • Four 5mm wide grey Phillips screws on the logic board.
    • One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
    • Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
  7. Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 7 中的图像 1,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 7 中的图像 2,3 Huawei Ideos S7 Slim Touchscreen Replacement: 步骤 7 中的图像 3,3
    • Disconnect the five cables connected to the logic board and then carefully lift the logic board out of the casing.
  8. Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: 步骤 8 中的图像 1,3 Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: 步骤 8 中的图像 2,3 Huawei Ideos S7 Slim Touchscreen Replacement, Touchscreen: 步骤 8 中的图像 3,3
    • Tilt the tablet on its lengthy side, place your thumbs on the side and gently separate the LCD from the touchscreen.
结论
2等其他人完成本指南。
Gregory Philip
于09/21/16注册
585 声望
创作了4篇指南
团队
UC Davis, Team 1-1, Oliver Fall 2016 UC Davis, Team 1-1, Oliver Fall 2016 的会员
UCD-OLIVER-F16S1G1
5 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 12
总计 1,295
