简介
Screen replacement is one of the most common smartphone repairs. This guide will help you remove the broken screen and install a new one on Huawei Honor 9X. One specifity with this smartphone is that it has a pop-up frontal camera which must be disassembled to perform the repair. You can also use this guide to replace the battery since screen replacement includes the removal of it.
你所需要的
Turn off the phone
Use plastic picks and opening tools to remove the back cover
You can use a heat gun to soften the glue and reduce potential damage, but it is possible to remove the back cover without applying heat
Pay attention to not rip the flex connecting the fingerprint sensor to the motherboard, place the back cover next to the phone after separating them as shown in the image
Detach the black film covering the plate covering the motherboard
Be careful not to rip the film since it contains flexes and presumably temperature sensors
Unscrew 11 screws holding the plate covering motherboard and remove it
Remove the screw holding the flex going from the frontal camera
Disconnect the flexes going to the motherboard from the buttons, the screen, the battery, the bottom circuit board, the fingerprint sensor and the frontal camera use of an opening tool is recommended
Remove the SIM/SD-card tray either with a tool coming with the phone or a needle of sufficient size, otherwise the cards, the tray or the motherboard may be broken
Remove the motherboard
Remove the speaker marked on the second image
Unscrew the screws holding the frontal camera. The 3 metallic screws are the only ones different from the rest screws, make sure not to lose them
Roll out the camera to its highest position and notice that there is one more screw you need to remove uinder the flex
Ensure that the frontal camera is in the lowest position before removing it
Remove the 6 screws holding the speaker and the circuit cover marked in the first picture
Remove the speaker and the plastic cover
Disconnect the flexes going to the motherboard marked in the second image
Remove the circuit board and the vibromotor
Follow the markers on the film attached to the battery to unfold the film and remove the battery
You may need to use some force to detach the battery by pulling the film out of the smartphone
Do not use any charp tools to not damage the battery!
Detach the film covering the flexes
Remove the flexes connecting the motherbord and the bottom circuit board
Remove the screen similarly to how you removed the back cover in Step 1
Clean the frame from the remaining glue and glass shards if such are present
You can check the new screen by connecting the flexes coming from it, the battery, and the buttons, and turning on the smartphone as you normally do. Turn it back off and disconnect the flexes before attempting next spep
Apply the glue to the inner edge of the frame and quickly (within 1-2 minutes) attach the new screen, turn the phone screen-down on a clean even surface and press on it for 1-2 minutes for better adhesion
Remove the residual glue if such appeared on the frontal side
To reassemble your device, follow the instructions from (including) Step 6 in reverse order. The cleaning of all parts from dust is recommended. The back cover should be glued to the frame using the E-8000 glue you used to attach the screen.
