跳转到主内容
修复你的物品
维修的权力
商店
已存档
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
已存档
  1. Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun. Attention: The sides have to be hot, not scalding. Insert the iSesamo delicatley between the two sides (see photo)
    • Heat the parts marked in red on the back side of the phone with a hair dryer or heat gun.
    • Attention: The sides have to be hot, not scalding.
    • Insert the iSesamo delicatley between the two sides (see photo)
    • Once the iSesamo is inserted, slide it along the sides to remove the adhesive.
    • ATTENTION: DO NOT SLIDE THE ISESEMO ALONG THE PART MARKED IN GREEN.
  2. Remove the screw on the metal plate which protects the fingerprint sensor cable Remove the the fingerprint censor cable using a plastic spudger.
    • Remove the screw on the metal plate which protects the fingerprint sensor cable
    • Remove the the fingerprint censor cable using a plastic spudger.
  3. Remove the 16 screws with  a Phillips screwdriver. Using the iSesamo, remove the protection from the motherboard Using the iSesamo, remove the protection from the motherboard
    • Remove the 16 screws with a Phillips screwdriver.
    • Using the iSesamo, remove the protection from the motherboard
  4. Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
    Essential 工具包
    我们最紧凑的套装中最有用的工具。
    现在开始购物
  5. Remove the 2 tabs marked in red. Gently remove the battery with a playing card or bank card. Gently remove the battery with a playing card or bank card.
    • Remove the 2 tabs marked in red.
    • Gently remove the battery with a playing card or bank card.
  6. Peel off the connector on the screen. Heat the contours of the screen as shown in Step 1.
    • Peel off the connector on the screen.
    • Heat the contours of the screen as shown in Step 1.
  7. insert the iSesamo between the screen and the chassis Be sure to pass the iSesamo under the white plate of the screen (see photo)
    • insert the iSesamo between the screen and the chassis
    • Be sure to pass the iSesamo under the white plate of the screen (see photo)
    • Go around the phone.
    • Note that the operation can be more complicated depending on the level of the screen.
  8. Carefully remove the pieces of glass and the adhesive on the frame Carefully remove the pieces of glass and the adhesive on the frame
    • Carefully remove the pieces of glass and the adhesive on the frame
    • Glue the screen on the frame by passing the sheet through the hole provided for this purpose
结论
To reassemble your device, follow the instructions in reverse order :)
4等其他人完成本指南。
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Nihoul Victor
于2017年04月23日注册
261 信誉积分
撰写一个指南
Est-ce que quelqu'un a essayer ? a combien estimez vous la réparation: ecran + accessoires ? Car le lien ne fonctionne pas. En tout cas tuto très bien réalisé ;)
fabien6-8ol - 回复
Moi forcement ...
Chez moi le lien fonctionne, la pièce est à 55,99€, tu peux demander des accessoires gratuit
Nihoul Victor - 回复
Bonjour
Merci pour ce tuto. J'aurais juste une question.
Comment recollé la vitre arrière après la réparation ?
J'ai déjà eu le cas sur un smartphone Sony et je n'ai pas réussi à correctement recollé la face arrière.
Merci a bientôt
Comoretto Quentin - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 5,207
