跳转到主内容
Huawei Honor 20 lite battery Replacement
你所需要的
  1. Huawei Honor 20 lite battery Replacement, heating back cover: 步骤 1 中的图像 1,1
    • Place phone on a heating bed.
    • I set it to 80 degrees celcius and left it on there for 5 minutes.
  2. Huawei Honor 20 lite battery Replacement, removing the back cover: 步骤 2 中的图像 1,1
    • once the glue is softened, use the plastic pick tool to loosen one edge.
    • leave a pick under one side to stop that side from re-sticking as you move onto the next edge.
  3. Huawei Honor 20 lite battery Replacement, undoing the screws: 步骤 3 中的图像 1,2 Huawei Honor 20 lite battery Replacement, undoing the screws: 步骤 3 中的图像 2,2
    • place the back cover side by side with the rest of he phone. being careful a the fingerprint scanner cable is on the back of the phone
    • take out all the screws in the bottom part of the phone and gently lift off, away from the phone.
    • unclip the ribbon cable.
  4. Huawei Honor 20 lite battery Replacement, top screws: 步骤 4 中的图像 1,1
    • next repeat the same process along the top part. (be careful with the cameras, the cover should just unclip without much effort.)
    • be careful of the 2 screws circled. these need to come out as well.
  5. Huawei Honor 20 lite battery Replacement, pulling battery tabs: 步骤 5 中的图像 1,2 Huawei Honor 20 lite battery Replacement, pulling battery tabs: 步骤 5 中的图像 2,2
    • gently pry the battery terminal away from the board
    • next pull tab 1 and 2 individually.
  6. Huawei Honor 20 lite battery Replacement, battery removal: 步骤 6 中的图像 1,1
    • when you pull tab 3, the battery should hinge away from you and then pull towards you .
    • insert a new battery and repeat the steps backwards.
结论
另外一个人完成了本指南。
chris dodds
于11/15/20注册
145 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 25
过去 30 天: 110
总计 945
