你所需要的
Power off the device.
Remove the phone case.
Use a SIM tray ejector tool to eject the SIM tray. Put the SIM tray and SIM card to one side.
Put the phone on its front. Move a heat gun around the edge of the phone to loosen the adhesive under the back case. Apply heat for around one minute.
Insert a corner pick in between the back cover and side of the phone, and gently slide the pick all around the edge of the phone, cutting through the loose adhesive.
Lift the back case gently until it is separate from the rest of the phone. Lay the back case on its back.
Use a Phillips #00 Screwdriver to remove 9 blahblah screws.
Use a Phillips #00 Screwdriver to remove 3 blahblahblah screws.
Use a spudger to pry off the motherboard bracket.
Use a spudger to gently pry off the connector of the fingerprint reader cable.
Put the back case to one side.
Use a spudger to gently pry off the motherboard connector.
Use a spudger to gently pry off the battery connector.
Peel the 3 stickers in the given numbered order.
Firmly grip the stickers and peel the battery up.
Peel off the underlying sticker.
Put the phone on its back. Move a heat gun around the edge of the phone to loosen the adhesive under the screen. Apply heat for around one minute.
3等其他人完成本指南。
