跳转到主内容
Huawei Ascend W1 Speaker Replacement
你所需要的
  1. Huawei Ascend W1 Speaker Replacement, The phone's orientation.: 步骤 1 中的图像 1,1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Speaker Replacement, Removing the back cover.: 步骤 2 中的图像 1,1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Speaker Replacement: 步骤 3 中的图像 1,1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Speaker Replacement, Removing the battery.: 步骤 4 中的图像 1,3 Huawei Ascend W1 Speaker Replacement, Removing the battery.: 步骤 4 中的图像 2,3 Huawei Ascend W1 Speaker Replacement, Removing the battery.: 步骤 4 中的图像 3,3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Speaker Replacement, Remove all the screws: 步骤 5 中的图像 1,2 Huawei Ascend W1 Speaker Replacement, Remove all the screws: 步骤 5 中的图像 2,2
    • After removing the battery, you will need to remove the screws holding the phone's middle cover.
    • There are eleven screws that hold the plate to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot. It is used as a tampering deterrent.
  6. Huawei Ascend W1 Speaker Replacement, Removing the lower circuit plate: 步骤 6 中的图像 1,2 Huawei Ascend W1 Speaker Replacement, Removing the lower circuit plate: 步骤 6 中的图像 2,2
    • After all the screws are removed from the back circuit, use your fingers to remove the lower section of the middle cover.
    • Grab the top of the lower middle cover and pull it outward towards you, exposing the circuit board underneath.
  7. Huawei Ascend W1 Speaker Replacement, Removing the rest of the middle cover.: 步骤 7 中的图像 1,2 Huawei Ascend W1 Speaker Replacement, Removing the rest of the middle cover.: 步骤 7 中的图像 2,2
    • Begin working your way around the sides of the middle cover, unsnapping it gently.
    • Be gentle as you pry the middle cover off. The parts may break if you are too forceful.
  8. Huawei Ascend W1 Speaker Replacement, Removing the speaker: 步骤 8 中的图像 1,3 Huawei Ascend W1 Speaker Replacement, Removing the speaker: 步骤 8 中的图像 2,3 Huawei Ascend W1 Speaker Replacement, Removing the speaker: 步骤 8 中的图像 3,3
    • The speaker is attached to the inside of the back cover and visible once the middle cover is removed.
    • Using small pliers, gently remove the speaker.
    • The speaker may be difficult to remove due to the adhesive that keeps it in place.
结论
2等其他人完成本指南。
Jaie Hillery
于10/07/14注册
1,718 声望
创作了10篇指南
团队
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G6
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 699
