跳转到主内容
Huawei Ascend W1 Rear Camera Lens Replacement
你所需要的
  1. Huawei Ascend W1 Rear Camera Lens Replacement, The phone's orientation.: 步骤 1 中的图像 1,1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the back cover.: 步骤 2 中的图像 1,1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Rear Camera Lens Replacement: 步骤 3 中的图像 1,1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 步骤 4 中的图像 1,3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 步骤 4 中的图像 2,3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: 步骤 4 中的图像 3,3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: 步骤 5 中的图像 1,2 Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: 步骤 5 中的图像 2,2
    • After removing the battery, remove the 2mm screws using a T5 Torx screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
  6. Huawei Ascend W1 Rear Camera Lens Replacement: 步骤 6 中的图像 1,2 Huawei Ascend W1 Rear Camera Lens Replacement: 步骤 6 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently press against the back of the lens from the back of the frame.
    • Use tweezers to pry off the lens from the front of the frame.
结论
Tanner Cline
于11/01/18注册
169 声望
创作了2篇指南
团队
IUPUI, Team S3-G2, Harley Fall 2018 IUPUI, Team S3-G2, Harley Fall 2018 的会员
IUPUI-HARLEY-F18S3G2
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 151
