跳转到主内容
Huawei Ascend W1 Motherboard Replacement
你所需要的
  1. Huawei Ascend W1 Motherboard Replacement, The phone's orientation.: 步骤 1 中的图像 1,1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Motherboard Replacement, Removing the back cover.: 步骤 2 中的图像 1,1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Motherboard Replacement: 步骤 3 中的图像 1,1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Motherboard Replacement, Removing the battery.: 步骤 4 中的图像 1,3 Huawei Ascend W1 Motherboard Replacement, Removing the battery.: 步骤 4 中的图像 2,3 Huawei Ascend W1 Motherboard Replacement, Removing the battery.: 步骤 4 中的图像 3,3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Motherboard Replacement, Remove all the screws.: 步骤 5 中的图像 1,2 Huawei Ascend W1 Motherboard Replacement, Remove all the screws.: 步骤 5 中的图像 2,2
    • After removing the battery, remove the screws using a T6 screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
    • The screw that is marked by the orange circle is covered by a white dot.
  6. Huawei Ascend W1 Motherboard Replacement, Removing lower section of the middle cover.: 步骤 6 中的图像 1,3 Huawei Ascend W1 Motherboard Replacement, Removing lower section of the middle cover.: 步骤 6 中的图像 2,3 Huawei Ascend W1 Motherboard Replacement, Removing lower section of the middle cover.: 步骤 6 中的图像 3,3
    • After all the screws are removed, use your fingers to remove the lower section of the middle cover.
    • Pull the lower section of the middle cover outward towards you, exposing the circuit board underneath.
  7. Huawei Ascend W1 Motherboard Replacement, Removing the rest of the middle cover.: 步骤 7 中的图像 1,3 Huawei Ascend W1 Motherboard Replacement, Removing the rest of the middle cover.: 步骤 7 中的图像 2,3 Huawei Ascend W1 Motherboard Replacement, Removing the rest of the middle cover.: 步骤 7 中的图像 3,3
    • Begin working your way around the sides of the cover plate, unsnapping it gently.
    • The middle cover is a thin piece of plastic with the external speaker inside of it.
    • Be gentle as you remove circuit cover. The parts might break if you are too forceful.
  8. Huawei Ascend W1 Motherboard Replacement, Locating the antenna.: 步骤 8 中的图像 1,2 Huawei Ascend W1 Motherboard Replacement, Locating the antenna.: 步骤 8 中的图像 2,2
    • The middle covers are removed.
    • The antenna is a thin white wire that connects to the circuit board in two locations.
  9. Huawei Ascend W1 Motherboard Replacement, Removing the antenna: 步骤 9 中的图像 1,2 Huawei Ascend W1 Motherboard Replacement, Removing the antenna: 步骤 9 中的图像 2,2
    • Lift gently at each connector of the white wire to disconnect the antenna from the port.
  10. Huawei Ascend W1 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,3 Huawei Ascend W1 Motherboard Replacement, Motherboard: 步骤 10 中的图像 2,3 Huawei Ascend W1 Motherboard Replacement, Motherboard: 步骤 10 中的图像 3,3
    • Use a plastic spudger or your fingers to gently pry up the four flex cables from the main board.
  11. Huawei Ascend W1 Motherboard Replacement: 步骤 11 中的图像 1,2 Huawei Ascend W1 Motherboard Replacement: 步骤 11 中的图像 2,2
    • With the back of the phone facing you, there will be a small black clip on the left side holding the main board in place.
    • Gently pry up near the small black clip with your fingers or a plastic spudger to detach the main board.
结论
另外一个人完成了本指南。
Jaie Hillery
于10/07/14注册
1,718 声望
创作了10篇指南
团队
USF Tampa, Team 16-6, Blackwell Winter 2016 USF Tampa, Team 16-6, Blackwell Winter 2016 的会员
USFT-BLACKWELL-W16S16G6
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 931
